Insert page: Check and validate against 2 database fields
Thread begun 12/31/2020 6:49 am by msbannister373603 | Last modified 1/06/2021 10:09 am by Ray Borduin | 5196 views | 16 replies |
msbannister373603
I have the following code. I'm trying to validate against 2 database fields before insert. If player_name and grad_year are the same don't allow the insert. This code works but it only works on player_name. It's ignoring the second part of my query. It looks like I have the query correct so I'm guessing it's the order or syntax of the php script. Any help appreciated.
//check.php
if(isset($_POST["Insert"]))
$player_name = mysqli_real_escape_string($connect, $_POST["player_name"]);
$grad_year = mysqli_real_escape_string($connect, $_POST["grad_year"]);
$query = "SELECT * FROM players WHERE player_name = '".$player_name."'AND grad_year = '".$grad_year."' ";
$result = mysqli_query($connect, $query);
echo mysqli_num_rows($result);
$InsertQuery = new WA_MySQLi_Query($tsrbase);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "players";
$InsertQuery->bindColumn("player_name", "s", "".((isset($_POST["player_name"]))?$_POST["player_name"]:"") ."", "WA_BLANK");
$InsertQuery->bindColumn("grad_year", "d", "".((isset($_POST["grad_year"]))?$_POST["grad_year"]:"") ."", "WA_ZERO");
$InsertQuery->saveInSession("WADA_Insert_players");
$InsertQuery->execute();
$InsertGoTo = "playersInsert.php?NewPW=Yes";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
I see a recordset and an insert, but I don't see the IF statement that validates no results were returned. Can you attach the full page so I can see it in context? That might help me identify the issue.
msbannister373603
Reply
<?php require_once("../../webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once('../../Connections/tsrbase.php'); ?>
<?php require_once("../../webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once('../../webassist/mysqli/queryobj.php'); ?>
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
$WADAMenugrad_year = new WA_MySQLi_RS("WADAMenugrad_year",$tsrbase,0);
$WADAMenugrad_year->setQuery("SELECT playersID FROM players");
$WADAMenugrad_year->execute();?>
$gradYear = new WA_MySQLi_RS("gradYear",$tsrbase,0);
$gradYear->setQuery("SELECT * FROM grad");
$gradYear->execute();?>
//check.php
$player_name = mysqli_real_escape_string($tsrbase, $_POST["player_name"]);
$grad_year = mysqli_real_escape_string($tsrbase, $_POST["grad_year"]);
$InsertGoTo = "playersInsert.php?";
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Team Sports Registry Admin Panel</title>
<!-- Bootstrap -->
<link href="../../css/bootstrap-4.4.1.css" rel="stylesheet">
<link href="../../css/main.css" rel="stylesheet" type="text/css">
<link href="../../css/navLinks.css" rel="stylesheet" type="text/css">
<link href="../../css/table.css" rel="stylesheet" type="text/css">
<script src="../../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.2.0/jquery.min.js"></script>
<link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/css/bootstrap.min.css" />
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.6/js/bootstrap.min.js"></script>
<link href="../../webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css">
<link rel="stylesheet" href="../../webassist/jq_validation/Bloom.css">
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
<link href="../../webassist/forms/dataassist_button.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="header" class="container">
<div class="row">
<div class="col-xl-5"><img src="../../vectors/tsrBlack.gif" alt="TSR Logo" class="img-fluid" id="tsrLogo"></div>
<div class="col-xl-6"></div>
</div>
</div>
<div id="navDirect" class="container">
<nav class="navbar navbar-expand-lg navbar-dark" style="background-color:#D0D0D0"> <a class="navbar-brand" href="#">Team Sports Registry</a>
<button class="navbar-toggler" type="button" data-toggle="collapse" data-target="#navbarSupportedContent1" aria-controls="navbarSupportedContent1" aria-expanded="false" aria-label="Toggle navigation"> Menu<span class="navbar-toggler-icon"></span> </button>
<div class="collapse navbar-collapse" id="navbarSupportedContent1">
<ul class="navbar-nav mr-auto col-xl-10">
<li class="nav-item active"> <a class="nav-link" href="javascript:history.go(-1)">Go Back<span class="sr-only">(current)</span></a> </li>
<li class="nav-item"> <a class="nav-link" href="../myPanel.php">Home</a> </li>
<li class="nav-item dropdown"> <a class="nav-link dropdown-toggle" href="#" id="navbarDropdown1" role="button" data-toggle="dropdown" aria-haspopup="true" aria-expanded="false"> Control Panels </a>
<div class="dropdown-menu" aria-labelledby="navbarDropdown1"> <a class="dropdown-item" href="../myPanel.php">Home Control Panel</a>
<a class="dropdown-item" href="../myTeams.php">Rosters Control Panel</a><a class="dropdown-item" href="#">Public Control Panel</a> </div>
</li>
<li class="nav-item"> <a class="nav-link" href="file:///C|/wamp64/mike.html">Contact Us</a> </li>
<li class="nav-item"> <a class="nav-link" href="file:///C|/wamp64/mike.html">LogOut</a> </li>
</ul>
</div>
</nav>
</div>
<div id ="intro" class="container">
<div class="row">
<div class="col-xl-12"><div class="row">
<div id="namePage" class="col-xl-7">Players</div>
</div></div>
</div>
</div>
<?php if(isset($_GET['NewPW'])){ ?>
<div id="success" class="container">
<div class="row">
<div class="error" style="width:90%;">
<div class="alert alert-primary" role="alert">
The Player has been added to your Database!
</div></div>
</div></div>
</div><?php } ?>
<form class="Basic_Default" id="Insert_Basic_Default" name="Insert_Basic_Default" method="post" action="">
<div id="content" class="container">
<div class="input-group mb-3">
<div class="input-group-prepend">
<span class="input-group-text" id="basic-addon1">Player Name</span>
</div>
<input type="text" id="player_name" name="player_name" class="form-control" aria-label="Username" aria-describedby="basic-addon1"value="<?php echo((isset($_GET["invalid"])?ValidatedField("coachinsert","coach_name"):"")); ?>" tabindex="1" title="Please enter a value." required="true">
if (ValidatedField('playerinsert','playerinsert')) {
if ((strpos((",".ValidatedField("playerinsert","playerinsert").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="player_name_ServerError">Please enter a value.</span><?php //WAFV_Conditional coach_insert.php coachinsert(1:)
</div>
</div>
<div class="col-xl-6"><select class="btn btn-secondary dropdown-toggle" name="grad_year" id="grad_year" rel="<?php echo((isset($_GET["invalid"])?ValidatedField("playersinsert","grad_year"):"")); ?>" tabindex="2" title="Please enter a value." required="true"><option value="" <?php if (!(strcmp("", (isset($_GET["invalid"])?ValidatedField("playersinsert","grad_year"):"")))) {echo "selected=\"selected\"";} ?>>Choose Grad Year</option>
while(!$gradYear->atEnd()) { //dyn select
<option value="<?php echo($gradYear->getColumnVal("gradYear")); ?>"<?php if (!(strcmp($gradYear->getColumnVal("gradYear"), (isset($_GET["invalid"])?ValidatedField("playersinsert","grad_year"):"")))) {echo "selected=\"selected\"";} ?>><?php echo($gradYear->getColumnVal("gradYear")); ?></option>
$gradYear->moveNext();
} //dyn select
$gradYear->moveFirst();
</select>
if (ValidatedField('playersinsert','playersinsert')) {
if ((strpos((",".ValidatedField("playersinsert","playersinsert").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
?><span class="serverInvalidState" id="grad_year_ServerError">Please enter a value.</span><?php //WAFV_Conditional players_insert.php playersinsert(2:)
}?></div><div id="button" class="row">
<div class="col-xl-12"><input class="btn btn-primary" type="submit" value="Insert" id="Insert" name="Insert" /></div>
</div>
</div>
</div><!--End of Container Tag-->
</form>
<div id="footer" class="container">
<div class="row">
<div class="col-xl-12">Content goes here | Placeholder Text | Placeholder Text | Placeholder Text</div>
</div>
</div>
<!-- jQuery (necessary for Bootstrap's JavaScript plugins) -->
<script src="../../js/jquery-3.4.1.min.js"></script>
<!-- Include all compiled plugins (below), or include individual files as needed -->
<script src="../../js/popper.min.js"></script>
<script src="../../js/bootstrap-4.4.1.js"></script>
<div id="Insert_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('Insert_Basic_Default', 'Insert_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="Insert_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="../../webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
<script src="../../webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<script src="../../webassist/jq_validation/jquery.h5validate.js"></script>
<script>
var Insert_Basic_Default_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "Bloom",
pointedAt: "left",
fieldOffset: 10,
fieldMargin: 2,
position: "left",
direction: "left",
border: 1,
offset: 25,
closeText: "✖",
percentWidth: 100,
orientation: "bottom"
function Insert_Basic_Default_Validate() {
$("#Insert_Basic_Default").h5Validate(Insert_Basic_Default_Opts);
$(document).ready(function () {
ConvertServerErrors(Insert_Basic_Default_Opts);
</script>
</body>
</html>
I think you need:
//check.php
if(isset($_POST["Insert"])) {
$player_name mysqli_real_escape_string($tsrbase$_POST["player_name"]);
$grad_year mysqli_real_escape_string($tsrbase$_POST["grad_year"]);
$query "SELECT * FROM players WHERE player_name = '".$player_name."'AND grad_year = '".$grad_year."' ";
$result mysqli_query($connect$query);
  if (
mysqli_num_rows($result) == 0) {
$InsertQuery->Action "insert";
$InsertQuery->Table "players";
$InsertQuery->bindColumn("player_name""s""".((isset($_POST["player_name"]))?$_POST["player_name"]:"") ."""WA_BLANK");
$InsertQuery->bindColumn("grad_year""d""".((isset($_POST["grad_year"]))?$_POST["grad_year"]:"") ."""WA_ZERO");
$InsertGoTo "playersInsert.php?";
if (
function_exists("rel2abs")) $InsertGoTo $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
msbannister373603
Validate 2 columns
Hi Ray. Thx for sending. I tried to run what you sent and it loads fine but the query still doesn't work. I added a bracket after the line ($result = mysqli_query($connect, $query);). Once I added the bracket the query works how I want it to work. However, the page does not load properly. It will load but I get an error message at the top of the page. Undefined variable result on line 31. Line 31 is the line with the if (mysqli_num_rows($result) == 0) {. Also, I get the error
Warning: mysqli_num_rows() expects parameter 1 to be mysqli_result, null given in C:\wamp64\www\registry\Admin\players\playersInsert.php on line 31
Here is the code I'm using that is working properly with the error on load
//check.php
$grad_year =mysqli_real_escape_string($tsrbase, $_POST["grad_year"]);
$result = mysqli_query($tsrbase, $query);
if (isset($_POST["Insert"]) || isset($_POST["Insert_x"])) {
Maybe the missing space in:
should be:
$query = "SELECT * FROM players WHERE player_name = '".$player_name."' AND grad_year = '".$grad_year."' ";
msbannister373603
That didn't work. It's working fine except for the 2 error messages upon loading. Also, upon submission, instead of inserting the data with the next auto-incremented number for some reason the next auto-incremented ID number is 1,226; when the next number should be 89. I'm sure it's something simple. Thx
What two error messages are showing upon loading?
You can reset your auto increment value with this statement:
ALTER TABLE `players` AUTO_INCREMENT = 89;
msbannister373603
Ray, Here is are the errors I get using the folloiwng code: Again, this works but I get the error messages. Also, the insert uses the auto number of 1289 instead of the correct auto number which the next insert should be 89. Not sure why but I can live with that I guess. I do konw how to reset the auto increment but that's not the issue. Thx Mike
//check.php
try:
//check.php
$grad_year =mysqli_real_escape_string($tsrbase$_POST["grad_year"]);
$result mysqli_query($tsrbase$query);
  if (
$InsertGoTo "playersInsert.php?NewPW=Yes";
if (
