Map Stop Showing
Thread begun 12/26/2020 3:15 pm by ccdantas101117 | Last modified 12/27/2020 1:09 pm by Ray Borduin | 631 views | 1 replies |
ccdantas101117
Map Stop Showing
I have a new API Key generated and the map still not showing with an error message on the map. I also noticed in the website console a message saying Version 2 is going to end on may 2021. Need help to identify where and what is causing the error and map not loading.
Most likely you have to update the permissions on the API key you are using. You may also have to update your billing information on the google api manager page. Log into google api manager and it should have an error log with reasons you can use to figure out which issue is causing your problem.
