Trying to do a multiple insert into 2 tables
Thread begun 12/22/2020 4:27 am by Sweens | Last modified 3/16/2021 9:57 am by Ray Borduin | 2304 views | 5 replies |
Sweens
Hi Ray
I'm trying to insert new users into two tables, users and site_members.
I want the newly created users.UserID from the first insert behaviour to be inserted into the site_members.sm_user_id field - but it doesn't appear in the list of available fields.
(The insert single record behaviour creates a session variable for the field, so I can do it for adding records individually).
Any directions much appreciated.
Cheers
Chris
If I'm understanding you correctly, this will have to be hand coded.
I see your queryobj and rsobj includes are too low on the page... move those up.
Then you can manually add code to the first multiple insert code to make it do two inserts like:
if (isset($_POST["btnAdduser"]) || isset($_POST["btnAdduser_x"])) {  // updated manually
$MultipleInsertConnection = $connEGM_i;
$MultipleInsertTable = "users";
$MultipleInsertRedirect = "2-users_MultiInsert.php?ins=success";
$MultipleInsertCheck = "fmEmail";
$MultipleInsertIdentifier = 'wamultiinsert_1';
  for (
$mi=0; $mi<sizeof($_POST[$MultipleInsertIdentifier]); $mi++) {
$MultipleInsertCount = $_POST[$MultipleInsertIdentifier][$mi];
    if ((
$MultipleInsertCheck == "" || (isset($_POST[$MultipleInsertCheck.'_'.$MultipleInsertCount]) && $_POST[$MultipleInsertCheck.'_'.$MultipleInsertCount]!=""))) {
$InsertQuery = new WA_MySQLi_Query($MultipleInsertConnection);
$InsertQuery->Action = "insert";
$InsertQuery->Table = $MultipleInsertTable;
$InsertQuery->bindColumn("UserEmail", "s", "".((isset($_POST["fmEmail"."_".$MultipleInsertCount]))?$_POST["fmEmail"."_".$MultipleInsertCount]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("UserPassword", "s", "".((isset($_POST["pwd"."_".$MultipleInsertCount]))?$_POST["pwd"."_".$MultipleInsertCount]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("UserFirstName", "s", "".((isset($_POST["firstname"."_".$MultipleInsertCount]))?$_POST["firstname"."_".$MultipleInsertCount]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("UserLastName", "s", "".((isset($_POST["surname"."_".$MultipleInsertCount]))?$_POST["surname"."_".$MultipleInsertCount]:"")  ."", "WA_IGNORE");
$InsertQuery->bindColumn("UserEmailVerified", "i", "1", "WA_IGNORE");
$InsertQuery->execute();
$InsertQuery2 = new WA_MySQLi_Query($MultipleInsertConnection);
$InsertQuery2->Action = "insert";
$InsertQuery2->Table = "site_members";
$InsertQuery2->bindColumn("sm_site_id", "i", "".$InsertQuery->InsertID  ."", "WA_DEFAULT");
$InsertQuery2->bindColumn("sm_site_user", "i", "".$_SESSION['SiteID']  ."", "WA_DEFAULT");
$InsertQuery2->bindColumn("sm_userlevel", "i", "2", "WA_DEFAULT");
$InsertQuery2->execute();
  if (
$MultipleInsertRedirect) {
    if (
function_exists("rel2abs")) $MultipleInsertRedirect = rel2abs($MultipleInsertRedirect,dirname(__FILE__));
header("location: " . $MultipleInsertRedirect);
Then delete the second multiple insert entirely.
Sweens
Hi Ray
Thank you so much - modified a field name and it works a treat!
Just need to add validation to the email address now.
Many thanks, once more, and best wishes for Christmas and beyond.
Cheers
Chris
Sweens
Hi Ray
I don't know if I should have done this first, but I'm having difficulty in not allowing duplicate values on the email address. When I go to add the behaviour, the two fields listed are wamultiinsert_1[] csv and wamultiinsert_1[] (array).
If I add either field as the one to check, records are inserted even if the email address already exists.
Cheers
Chris
The multiple insert doesn't really have unique value validation options.
This is something that would have to be hand coded to do properly. I could help in a premier support ticket.
Sweens
Hi Ray
Yes, no problem. See pm
