DataAssist Search Issue searching with "And"
Thread begun 12/16/2020 9:59 am by keith505 | Last modified 12/16/2020 2:41 pm by Ray Borduin | 699 views | 2 replies |
keith505
I have a column that contains for example:
Viola
Violin and Piano
Orchestra
Viola with Orchestra
When I do a search on the above field that includes the word "and" I get no results when there are many results. The generated SQL looks correct: "Search AND (Instruments = 'Viola and Piano')" however, it appears to me the "AND" is causing trouble somewhere. It is only the fields with AND that have this issue. Any thoughts about this?
keith505
I have attached FTP info in private message if it would be helpful.
I've updated your search and results page to address this issue. You can use comma separated values in the search field to search for multiple instruments.
