unable to set menu value for lookup field
Thread begun 12/11/2020 7:54 am by software.current355386 | Last modified 12/14/2020 11:33 am by Ray Borduin | 2083 views | 7 replies |
when setting field when using dataassist page generation option can set the field type as menu but cannot set the options using the lightning button
even the ones generated earlier in year now don't work
changes to setup
dataassist v2
dw 2020
Big Sur OS
there are messages in the background but they disappear to quick for me to read.
is there a debugging/trace option available so I can attempt to find the cause/problem
Are the errors in the wizard or on the page? I'll need to reproduce the issue, so please give me specific steps and I can see if I can help.
Select bassist from topofscreeen
Database
data assist pages
Connection - Dbupdate
Application type - dbmftp (saved preset)
this filled in the table/key column/pagedesign
manage pages
Configure Field settings
scrolled down to menu field
clicked on the lightning bolt
the configuration window appears briefly at the same time there were several message appeared briefly in box about the size of a 6" ruler
tried about 20 times before its finally appeared, had to pre esc to gain access to the screen between attempts
This may be related to the preset you are using or your database connection. Please try reinstalling the extension. If the issue still occurs, then post your phone number in the private area of a reply and I'll call you to set up screen sharing and look into this with you.
c pm
I've sent you a message in Skype. Hopefully we can connect Monday and do screen sharing to look into this issue.
lookin a vidoclip i sent u slowing it down the messages that were flashing up said trying to loading dataabse schema.
tried to alter dataassist pages .. mesage flashe up then loched the process. clikd on anoth windoe snd t freed up snd i could complelte the task
I'm in skype now... message me: webassist.rborduin
