Microsoft VBScript runtime error '800a005e'. Invalid use of Null: 'CStr'
Thread begun 12/11/2020 5:26 am by Nathon Jones Web Design | Last modified 12/16/2020 8:35 am by Ray Borduin | 3961 views | 4 replies |
Why would this...
' WebAssist iRite: Rich Text Editor for Dreamweaver
Dim WARichTextEditor_1 : Set WARichTextEditor_1 = CreateRichTextEditor ("SWPCsummary", "../WA_iRite/", "97%", "200px", "Custom", "../custom/edit-property-details_SWPCsummary1.js", "" & cStr((rsEDITPROP.Fields.Item("SWPCsummary").Value)) & "")
...now be throwing the following error:
/swpcadmin/edit-property-details.asp, line 283
Page attached.
Thank you.
NJ
The value of this:
is null.
What might the issue be if the value of:
...isn't null?
This is happening for all of the rows in the database, and not one of them has a NULL value for the "SWPCsummary" field.
The Summary and Description fields both utilise iRite and I wondered if this was something to do with that? In particular the default value for these fields, which is taken from the database.
As you'll see, when you try to access this form it initially shows the first value "SWPCsummary" so to then display a problem with Null is confusing.
Log in details and information are provided below.
Thank you.
NJ
It appears that in your code a variable becomes null after referencing it once. I'm not sure why, but you were populating a <textarea> above the text editor with the same value. Once I removed the textarea tag above, the rich text editor began to work properly on the page.
The only thing I can think of is that I opened this page, which has been working fine for almost a decade (!), in the latest version of Dreamweaver and I wonder if it tried to edit/update the ASP code? It has clearly added additional textarea fields that weren't there before anyway.
Appreciate the help Ray. Have forwarded a donation payment for that.
NJ
