adding font & styles setting autofocus
Thread begun 12/08/2020 5:12 am by software.current355386 | Last modified 12/08/2020 10:24 am by Ray Borduin | 618 views | 1 replies |
Is it possible to setup personal styles/default font to be used by html editor (v2 dataassist)
within a form field definition you can set the field to auto focus on our chosen field to be come active on load, its it possibe to do same in html editor
The html editor we use is called CKEditor. You can do a lot with it using their api, including accomplishing the two things you ask about here. Just use google to find associated articles like:
"ckeditor set focus on load"
"ckeditor add custom fonts and styles"
You should be able to find whatever you need in their help documentation and forums.
