Dreamweaver crashes building DataAssist pages
Thread begun 11/23/2020 3:59 pm by DeanCollins | Last modified 3/20/2022 5:00 pm by Ray Borduin | 1577 views | 5 replies |
DeanCollins
Dreamweaver CC 2021
Data Bridge V2 Current version: 2.3.5
MySQLi Server Behaviors Current version: 1.0.8
Old Server Behaviors installed
When I click "Finish" to build the pages, I get two errors.
Javascript errors occurred:
In file: "file:///C|/Program Files/Adobe/AdobeDreamweaver2021/Configuration/Floaters/WA_SiteTools_ProgramV2.htm":MM.WA_SiteToolsProcessingObjectV2 has no properties
error occured in DA updateProgress:
Type error: docment.getElementByID("fullProgress") has no properties
Then Dreamweaver crashes.
Please post a US phone number or Skype contact information and I'll give you a call to debug this and help you get it working in a screen sharing session.
DeanCollins
Info in the private message
We cleared out the configuration folder and reinstalled the extension and this appears to have fixed the problem. It may have been an issue with an older version of MySQLi Server Behaviors and/or Deprecated Server Panels extensions being installed after Data Bridge. Data Bridge includes all of the functionality from both of these, so they should not be installed, and even be removed before installing Data Bridge to prevent conflicts.
msmoose2400634
Getting the same error
Ray, did the the following instructions as you suggested (above) reinstalling the Server Behavior extension but I am still getting the same errors.; I click the ok button 31 times and then this appears, (see attachments as there are a number of screen images, pictures are worth a 1000 words).
It does appear to be an issue with the install or with a conflict with another extension. Can I see a screen grab of your installed extensions?
Try reinstalling just DataBridge. If that doesn't work, then I can set up a screen sharing session with you Tuesday and I can debug it and get it resolved for you.
