How to style DataAssist pages with Bootstrap?
Thread begun 11/19/2020 7:31 am by SCar87011738 | Last modified 11/19/2020 7:51 am by Ray Borduin | 702 views | 1 replies |
SCar87011738
hello all,
I would like to join the power of dataassist pages with the easy-to-style bootstrap framework.
Actually, even if I select UNSTYLED from the DataAssist pages I get lots of tags/classes around fields. It's hard to put bootstrap code inside this pages.
Is there a way to create a Bootstrap style for DataAssist page?
This would boost administrative pages building a lot.
TIA
tony
The tags and classes don't do anything without assigning a style sheet that references them.
You can also drag the input fields out of the divs after generation to re-arrange them into any design you want.
I use databridge with bootstrap and I don't remove the tags. I define my own style sheet to go with the design I want and reference the classes. I think having the classes around the fields give me flexibility and aren't a limitation.
I'm not sure what exactly you would want from the design without specifics for what it is that throws off the design or what you are going for.
