chart.js with WA
Thread begun 11/03/2020 8:03 am by Jonas | Last modified 11/04/2020 9:25 am by Ray Borduin | 1923 views | 5 replies |
Jonas
chart.js with WA
I have found a movie that explains how to create dynamic charts (https://www.youtube.com/watch?v=cREXtrFiJBc).
The problem is that I do not understand how to do this using Webassist tool.
On their page, the database is called with full code, instead of referring to an include page which is common.
The select statement is also created here.
Then each line is looped to create a format that chart.js understands.
I enclose their file, as well as an attempt by me that does not work. Can anyone tell me how to do this with Webassist, thanks!
index.php is the source file that works, indexCopy.php is my attempt.
This code:
//loop through the returned data
    while ($row = mysqli_fetch_array($result)) {
        $data1 = $data1 . '"'. $row['data1'].'",';
        $data2 = $data2 . '"'. $row['data2'] .'",';
should be:
    while (!$sql->atEnd()) {
        $data1 = $data1 . '"'. $sql->getColumnVal("
data1").'",';
        $data2 = $data2 . '"'. $sql->getColumnVal("
data2") .'",';
$sql->moveNext()
I've attached a chart.js user registration chart example I created for another project you might get some ideas from.
Jonas
Im sorry, but It only displays the first value from the two datasets, in the chart?
<?php require_once('../../Connections/bucketListHub.php'); ?>
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
$data1 = '';
$data2 = '';
$sql = new WA_MySQLi_RS("sql",$bucketListHub,1);
$sql->setQuery("SELECT * FROM chartTst");
$sql->execute();
$data1 = $data1 . '"'. $sql->getColumnVal("data1").'",';
$data2 = $data2 . '"'. $sql->getColumnVal("data2") .'",';
$sql->moveNext();
$data1 = trim($data1,",");
$data2 = trim($data2,",");
should be:
$sql = new WA_MySQLi_RS("sql",$bucketListHub,0);
Jonas
Now, when you say that, it sounds obvious.
For some reason, the number 0 does not appear in my bar graph (it starts at 1 on the y-axes), even though I typed 'beginAtZero: true'.
This is a bit annoying then, it is sometimes only value 1.
Here's the code:
$data = '';
$label = '';
$colorCode = '';
while (!$rsCount->atEnd()) {
$data = $data . '"'. $rsCount->getColumnVal("countEachCategory").'",';
$label = $label . '"'. $rsCount->getColumnVal("categoryName").'",';
$colorCode = $colorCode . '"'. $rsCount->getColumnVal("colorcode").'",';
$rsCount->moveNext();
$data = trim($data,",");
$label = trim($label,",");
$colorCode = trim($colorCode,",");
<script>
let labels = [<?php echo $label; ?>]
let data = [<?php echo $data; ?>];
let colors = [<?php echo $colorCode; ?>];
var ctx = document.getElementById("chart").getContext('2d');
var myChart = new Chart(ctx, {
type: 'bar',
data: {
labels: labels,
datasets:
label: '',
data: data,
backgroundColor: colors,
options: {
scales: {
scales: {
yAxes: [{
ticks: {
beginAtZero: true
tooltips: {
mode: 'index'
legend: {
display: false
</script>
You have:
options: {
scales: {
scales: {
yAxes: [{
it should be:
options: {
scales: {
yAxes: [{
,and remove the corresponding close }
