Inser / Update - error your SQL syntax
Thread begun 11/03/2020 5:08 am by georgina_barrett_187762 | Last modified 11/03/2020 12:08 pm by Ray Borduin | 734 views | 2 replies |
I have a content manger working perfectly on one of my sites. I have copied it and the database to another site hosted on a different server and for some reason I don't seem to be able to insert / update on some pages. I am getting an error your SQL syntax when I try and do it. Some inserts and updates on the content manager work and some don't. I have attached a copy of some of the files that don't work. I have checked to see if the datatyoes match with the database and as far as I can see they do. The strange thing is I have copied both the database and the content manger from a different domain that all works perfectly.
It is probably missing columns in the database. This isn't something I could spot in the code. If you give me a url with steps to reproduce and FTP access, then I could probably track it down.
You might try updating the queryobj.php file and changing the Debug setting to true. That might give you more information about the error to help you figure it out on your own.
That did it thank you. I changed the Debug setting to true in the queryobj.php file and it showed the error:
Field 'Email' doesn't have a default value
I have made it a NULL default value in the database and it works now.
