Issue following Dynamic Dropdowns with Data Bridge 2.0 tutorial
Thread begun 10/22/2020 1:52 am by Ashok | Last modified 10/27/2020 7:06 am by Ray Borduin | 786 views | 3 replies |
Ashok
Hello,
I am following this tutorial - Dynamic Dropdowns with Data Bridge 2.0
I am not getting the child list populated, instead the parent list is replaced by child list and list is empty.
I have attached the files.
The div: <div id="mainContent">
should be wrapped around the child list, not the parent list on the main page.
On the child select, the recordset should be filtered using the name of the parent select list: "country"
You have it filtered with: $_POST['countryid']
Change that to: $_POST['country']
Ashok
It's working now.
Can I have 2 instances of dependent drop-down on the same page?
Yes... you can have as many as you need.
