How to sort recordsets by header?
Thread begun 10/21/2020 11:55 am by LionsMane | Last modified 10/21/2020 12:31 pm by Ray Borduin | 1146 views | 3 replies |
LionsMane
I want my recordsets to be sortable when the user clicks on the column title. I'm using webassit recordsets and can display them fine, but resorting them up or down when clicking on the title would be a huge help. Suggestions
Use the webassist database sort server behavior that comes with DataBridge.
LionsMane
Dang
Thanks for the reply, but I don't have the $400 for this one function. Thanks all the same.
You could code it by hand using an ORDER BY in your recordset to specify the column you want sorted on. Have the link set a session variable that is placed into the the SQL statement to change the ORDER BY value.
