Server redirect with pass original query string without links from tab
Thread begun 10/19/2020 2:53 am by Jonas | Last modified 10/29/2020 10:20 am by Ray Borduin | 3624 views | 19 replies |
Jonas
I have two pages (master & detail).
The master page lists several products.
On the detail page are four different tabs. These tabs are linked through dynamic plug-in. I have set one of these pages to default, so it is automatically displayed when you get to the detail page. I have created session values for each tab button and server redirect with pass original query string selected. When you select the back button, you come to the master page.
Everything works so far.
But it seems that server redirect with pass original query string is "too" good. Because, the next time you click on another product on the master page, the last tab/page you selected on the detail page will appear. Not the tab/page as I have set as default.
I need server redirect with pass original query string because the link is complex. But at the same time, I do not want it to include which tab you have chosen - which it seems like now.
Can this be solved in any way?
What happens when you turn off "pass original query string"?
Jonas
Then, if I choose to update the page in the browser - the url cuts. For example if its turn on: merinformation.php?buc_id=85&return=../index.php.
And if its turn off: merinformation.php.
I think I'd have to debug this live to figure out what is going on. I'm not sure how it is remembering the tab. You may be able to just add code to the page to always re-open the default tab when the page is visited.
Jonas
Okay, that's not the way. Although it's a little annoying
Jonas
Now I have created a demo site that can be tested.
What do I do to reproduce the issue on the site once I get there? Please provide more detailed steps to reproduce.
Jonas
I have problem with the tabs. Then choose a product the detail page will open wrong tabs as default.
You were maintaining the selected tab in the session. To reset it I added code to the top of the index.php page:
@session_start();
if(isset(
$_SESSION["tablink"]))     {
$_SESSION["tablink"] = "info";
Jonas
Thanks! That make sense.
