Data Assist Search for text regardless of uppercase or lowercase letters
Thread begun 10/17/2020 4:24 am by Jonas | Last modified 10/19/2020 9:01 am by Ray Borduin | 675 views | 1 replies |
Jonas
Can you set DA search so it does not matter if you search in uppercase or lowercase letters?
I find it too sensitive with the settings I can find in DA Search. Because you have to know if what you are looking for, for example, starts with a capital letter or not.
That is a database setting. If you update the database column collation to anything that ends with "_ci" it will be "case insensitive".
You must have the database column set to case sensitive currently.
