International phone numbers issue (checkout form)
Thread begun 10/15/2020 1:57 pm by yogastudents362523 | Last modified 10/19/2020 2:46 pm by Ray Borduin | 2359 views | 6 replies |
yogastudents362523
Hello,
The input code including validations for telephone numbers on the checkout page are as follows:
<input id="Phone_Number" name="Phone_Number" type="text" value="<?php echo(WA_coalesce(array(WA_getSavedFormValue("CheckoutWizard_Basic_Default","Phone_Number"),(isset($_GET["invalid"])?ValidatedField("kofiAdonateconfirmcart","Phone_Number"):"")))); ?>" class="formTextfield_Large" tabindex="5" pattern="\(\d{3}\) \d{3}[\-]\d{4}" title="Please enter a 10 digit phone number" required="true" onBlur="WAValidatePN(document.getElementById('CheckoutWizard_Basic_Default').Phone_Number,'',false,true,'x (xxx) xxx-xxxx',document.getElementById('CheckoutWizard_Basic_Default').Phone_Number,0,true);">
I am concerned with the string of x's that seem to indicate the "picture" for telephone formats.
I am concerned that I have foreign people coming in to make Donations, and who then find that they cannot enter a valid number in that formatl
How would you advise that I handle this? I.e. somehow validate that only numbers are permissible, while allowing for greater flexibility of inputs.
Thank you,
KB
Remove the onBlur and pattern attributes and it will allow any entry.
yogastudents362523
Hello,
I tried various options for both removing and hiding various aspects of the above onBlur and pattern attributes, and none of them would work. Either the page would not load, or else I got errors.
I also tried hiding/removing the entire "<div class="lineGroup">" that holds the whole of that phone record, and the form responded by refusing to advance to the next page.
I am thinking that my best option is to do two things:
(A) Make that whole phone field optional,
(B) Remove the effects of that pattern.
How would I accomplish this for I am at present stumped!!
Thank you,
KB
Please attach the page so I can reference line numbers. Most likely my advice above is correct, but you probably have to update the server validation as well.
yogastudents362523
Hello,
Thank you.
I have attached the page.
It is the checkout page.
With every good wish,
KB
I removed the restrictions on the phone number format.
Please download the files: kofi_donate_pp_confirm.php, kofi_donate_confirm.php, donate_confirm_cart.php, donate_checkout.php
yogastudents362523
Hello,
Confirming that tested and was able to enter an International format with no problems.
Also (as per other posting) d/led files.
Thank you for your kindness,
KB
