How do I validate HTML Editor
Thread begun 10/12/2020 12:25 pm by Jonas | Last modified 10/13/2020 8:57 am by Ray Borduin | 1197 views | 3 replies |
Jonas
I do not understand how to validate HTML editor. I have looked through both articles on the forum and getting started tutorials that are about HTML Editor - but I still do not understand. No form field is written, so it is not possible to link this to Validation Show If?
You should be able to add server validation and a server show if by using the binding for the form element that is created.
You can add client validation by adding the following to the ckeditor code:
$CKEditor_config["props"] = array();
$CKEditor_config["props"]["required"] = true;
$CKEditor_config["props"]["min"] = 20;
$CKEditor_config["props"]["max"] = 1000;
Min and max are optional but allow you to set a minimum and maximum length.
Jonas
Okay, I'm now a little closer. I want server validation, not client. But the validation does not seem to work. I have managed to get the message "Please write a text", now displayed under the HTML editor. But it does not disappear when you start writing. What have I missed? However, the form is not sent if you have not written anything, which is quite so far.
Add the config settings I suggested above at around line 335 like:
