message length
Thread begun 9/26/2020 10:46 am by yogastudents362523 | Last modified 9/28/2020 9:04 am by Ray Borduin | 1478 views | 4 replies |
yogastudents362523
message length
Hello,
I can see from the "Design Content" field that PowerMessenger is set to 'Type: text'','Lenght: 0'.
I had a long message to create, and have discovered that PowerMessenger has arbitrarily cut off a rather long message I had wanted to send out. I had got used to its habit of losing all my edits with the occasional timeout, but this took me by surprise.
Is there any immediate way around this length limit? And ... could you indicate how many characters the current limitation is?
Thank you
With every good wish.
KB
yogastudents362523
Also ...
Should I try using the 'Use a File for Design' option? Or does it also imose the same kind of length limit?
Thank you,
KB
yogastudents362523
Would it be safe to switch 'type' to either of the 'mediumtext' or 'longtext' options?
Thank you,
KB
You should be able to change it to longtext without any issues and that should allow you to have very long content.
yogastudents362523
I did try that earlier in the day, and it did not seem to work.
I eventually sent my mailing out as separate Part I and Part II mailings.
I will try the 'longtext' option again probably tomorrow. It is more than likely that I made some error.
Thank you,
KB
