sql injection
Thread begun 9/22/2020 1:50 am by Sweens | Last modified 10/09/2020 9:09 am by Ray Borduin | 3690 views | 22 replies |
Sweens
sql injection
Hi Ray
Hope you can help with this. I have a couple of pages that Jason helped me with originally and you helped me convert them to mysql_i. They use checkboxes to select email recipients. I'm told that the following lines leave the page vulnerable to an sql injection and hope there is an easy fix.
line 16: $WAFV_Errors .= WAValidateRQ(((isset($_POST["toEmail"]))?implode(", ",$_POST["toEmail"]):"") . "",false,2);
line 58: $Email->addBCC("".((isset($_POST["toEmail"]))?implode(", ",$_POST["toEmail"]):"") ."");
I've attached the page.
Many thank
Chris
Those lines couldn't possible lead to sql injection... they aren't even tied to any database sql at all.
Sweens
Hi Ray
My apologies - wrong piece of code. It's in the page has the recipients recordset (in p.m.
Cheers
Chris
Try:
$rsRecips
= new WA_MySQLi_RS("rsRecips",$connRIBIT_i,0);
$rsRecips->setQuery("SELECT CONCAT(rotarians.FirstName, ' ', rotarians.Surname)AS RecipName FROM rotarians WHERE rotarians.MemEmail IN (?) AND ClubID=? AND rotarians.status=0 ORDER BY rotarians.Surname");
$rsRecips->bindParam("sl""".(isset($_POST['toEmail'])?$_POST['toEmail']:"-1") ."""-1"); //p1
$rsRecips->bindParam("i""".$_SESSION['ClubID'] ."""-1"); //p2
$rsRecips->execute();
Sweens
Thanks Ray
The emails are sent, but each contains the following error message:
Notice: Array to string conversion in /home/sites/6b/5/5827535cbb/public_html/webassist/email/Rotary/members-email_body.php on line 6
Cheers
Chris
You shouldn't have changed the email code... just the recordset select statement. It shouldn't have any effect on your email code.
Line 58 should still be:
What is on members-email_body.php on line 6?
Sweens
Hi Ray
Thanks. I haven't modified anything except the recordset.
Line 6 is from the new recordset code:
$rsRecips->bindParam("sl", "".(isset($_POST['toEmail'])?$_POST['toEmail']:"-1") ."", "-1"); //p1
Cheers
Chris
Try changing it to:
$rsRecips->bindParam("sl", (isset($_POST['toEmail'])?$_POST['toEmail']:"-1") , "-1"); //p1
Sweens
Thanks Ray
That seems to have fixed it - no error on the emails.
Many thanks once again. See pm
Chris
Sweens
Hi Ray
Something else has come up - see pm - is there a way round that? Client very concerned about GDPR.
Chris
