Make login email case insensitive
Thread begun 9/18/2020 1:54 am by Mags | Last modified 9/18/2020 9:14 am by Ray Borduin | 1486 views | 2 replies |
Mags
Hi Ray, I have a recurring issue on one of our client's sites where people sign up for an account and their email address is added with an initial capital, so when they then try to login with a lowercase email address it won't let them. I'm always having to go in and change their email addresses! I saw another post about this and you said adding /i to the end of the validation string would make it case insensitive, however I'm not sure where to add this. I've attached a copy of the login page, can you help?
You would be able to change the data type in the database to make it case insensitive. You can do this from phpMyAdmin. Just go to the table and edit the column to change the collation to something that ends in _ci (case insensitive).
Mags
I never knew that's what the _ci stood for..! Thanks, that worked!
