Cross Site Scripting (XSS) issues when using URL Queries that are shown in the address field
Thread begun 9/16/2020 11:10 am by Steve | Last modified 9/16/2020 12:52 pm by Ray Borduin | 1439 views | 4 replies |
Steve
I have a client that is getting flagged as having XSS vulnerabilities on their site.
For instance we have a generic page that uses the URL string as a value in the page. These are Cities and allow a number of pages to have some SEO benefit without having to write Content for each city.
Example:
https://www.savonhomes.com/cities.php?id=Riverside
But this string will also allow html tags such as :
https://www.savonhomes.com/cities.php?id=<h1>Riverside</h1>
This show that "tags" can be used in the page and is being flagged as an XSS vulnerability.
Personally I don't see how this could be a problem other than our client getting notices from companies that want to solve this condition.
Should I sanitize the URL parameter input prior to using in the page or is it best practice to disallow the page to render IF a certain characters are present (<> etc)?
Views?
Cross site scripting can be used in conjunction with iframes to steal cookies. The stolen cookies could be used to hijack sessions. Now, that may or may not be a big issue depending on what sensitive information your site may or may not contain about users.
In general, I would close XSS vulnerabilities... You can do that by using htmlspecialchars() to encode any potentially offending code before writing it to the page like:
<?php echo(htmlspecialchars($_GET["id"])); ?>
Steve
Thank you Ray. As always you are an invaluable resource to the community.
Steve
Actually I did not see merit in htmlspecialchars but found the strip_tags() function to remove all tags which seems effective in leaving only text in the URL parameter.
strip_tags() removes tags but won't encode quotes or even > characters outside of tags, which can be used to break out of tag or script blocks where the GET variable is referenced.
strip_tags may be enough in your application, but htmlspecialchars() is the more complete blocker for XSS attacks in all situations where they may occur.
