DW CC 2019 "Not Responding" any more when opening a file, installed DW CC 2020, installed WA extensions, it too is now "Not Responding"
Thread begun 9/16/2020 2:07 am by Nathon Jones Web Design | Last modified 9/17/2020 6:51 am by Ray Borduin | 2421 views | 5 replies |
Eventually, DW CC 2020 responds with...."a script in the file UNKNOWN is taking a long time to load" and the option to continue or not.
Opening the file in notepad I commented out the following block of code...
if (isset($_POST["addvenueBTN"]) || isset($_POST["addvenueBTN_x"])) {
$InsertQuery = new WA_MySQLi_Query($csdbmysqli);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "TradVenue";
$InsertQuery->bindColumn("NJdomainID", "i", "$domainID", "WA_DEFAULT");
$InsertQuery->bindColumn("NJuserID", "i", "".((isset($_POST["VENUEuID"]))?$_POST["VENUEuID"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueNAME", "s", "".((isset($_POST["venueNAME"]))?$_POST["venueNAME"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueCONTACT", "s", "".((isset($_POST["venueCONTACT"]))?$_POST["venueCONTACT"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueADD1", "s", "".((isset($_POST["venueADD1"]))?$_POST["venueADD1"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueADD2", "s", "".((isset($_POST["venueADD2"]))?$_POST["venueADD2"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueADD3", "s", "".((isset($_POST["venueADD3"]))?$_POST["venueADD3"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueADD4", "s", "".((isset($_POST["venueADD4"]))?$_POST["venueADD4"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueCITY", "s", "".((isset($_POST["venueCITY"]))?$_POST["venueCITY"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueREGION", "s", "".((isset($_POST["venueREGION"]))?$_POST["venueREGION"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueCOUNTRY", "i", "".((isset($_POST["venueCOUNTRY"]))?$_POST["venueCOUNTRY"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venuePOSTCODE", "s", "".((isset($_POST["venuePOSTCODE"]))?$_POST["venuePOSTCODE"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueLAT", "s", "".((isset($_POST["venueLAT"]))?$_POST["venueLAT"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueLONG", "s", "".((isset($_POST["venueLONG"]))?$_POST["venueLONG"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venuePHONE", "s", "".((isset($_POST["venuePHONE"]))?$_POST["venuePHONE"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueMOBILE", "s", "".((isset($_POST["venueMOBILE"]))?$_POST["venueMOBILE"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueEMAIL", "s", "".((isset($_POST["venueEMAIL"]))?$_POST["venueEMAIL"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueURL", "s", "".((isset($_POST["venueURL"]))?$_POST["venueURL"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueFACEBOOK", "s", "".((isset($_POST["venueFACEBOOK"]))?$_POST["venueFACEBOOK"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueTWITTER", "s", "".((isset($_POST["venueTWITTER"]))?$_POST["venueTWITTER"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueSUMMARY", "s", "".((isset($_POST["venueSUMMARY"]))?$_POST["venueSUMMARY"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueDESC", "s", "".((isset($_POST["venueDESC"]))?$_POST["venueDESC"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueOPENTIMES", "s", "".((isset($_POST["venueOPENTIMES"]))?$_POST["venueOPENTIMES"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueCAPACITY", "s", "".((isset($_POST["venueCAPACITY"]))?$_POST["venueCAPACITY"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueBOOKINGS", "s", "".((isset($_POST["venueBOOKINGS"]))?$_POST["venueBOOKINGS"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueDIRECTIONS", "s", "".((isset($_POST["venueDIRECTIONS"]))?$_POST["venueDIRECTIONS"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venuePARKING", "s", "".((isset($_POST["venuePARKING"]))?$_POST["venuePARKING"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueDISABLED", "s", "".((isset($_POST["venueDISABLED"]))?$_POST["venueDISABLED"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueTOILETS", "s", "".((isset($_POST["venueTOILETS"]))?$_POST["venueTOILETS"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueIMG", "s", "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("venueIMGCAP", "s", "".((isset($_POST["venueIMGCAP"]))?$_POST["venueIMGCAP"]:"") ."", "WA_DEFAULT");
if($_SESSION['NJinUSERID'] !== 1 || $_SESSION['NJinUSERID'] !== 100 || $_SESSION['NJinUSERID'] !== 117) {
$InsertQuery->bindColumn("venueAPPROVED", "i", "2", "WA_DEFAULT");
$InsertQuery->saveInSession("NEWvenueID");
$InsertQuery->execute();
$InsertGoTo = "add_event.php?av=1";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
...and when I open DW CC 2020 and open this file, it loads without crashing DW.
Why is this INSERT behaviour crashing DW CC, and how do I fix it?
Thank you.
NJ
It has something to do with the Dreamweaver regular expression engine.
When something comes close to matching, but then runs into issues, it causes a crash.
In this case it is the hand coding you did:
One solution to the problem is to make sure it breaks the match earlier... by adding a comment like:
if (isset($_POST["addvenueBTN"]) || isset($_POST["addvenueBTN_x"])) {  // hand coded
By adding the comment in the first line, it prevents dreamweaver from trying to match the rest where the crash occurs.
Ray, the crash is happening with and without the hand coding on this behaviour. I should have made that clear, sorry.
NJ
If you attach the file then I could take a look. My guess is that there is other hand coding... does the solution I gave fix it?
The solution you have given has resolved it, thank you Ray.
Has something changed in DW though? I have been using CC 2019 absolutely solidly for the past 12 months and have hand coded sections in the WA recordsets and behavious in a lot of projects, and have never had this problem.
Much appreciated.
NJ
I've known about this issue for 20 years... It isn't anything that has changed. It only happens for some server behaviors and it depends on where the hand coding appears.
