file manipulation not working
Thread begun 9/14/2020 10:31 am by Carlos Quintero | Last modified 9/14/2020 1:53 pm by Ray Borduin | 2145 views | 7 replies |
Carlos Quintero
For some reason the file manipulation will no longer upload files. Here is a test page that I created https://iaia.org/UploadTroubleShooting.php Error reporting is enabled.
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
POST:
array(1) {
["submit"]=>
string(6) "Submit"
FILES:
array(0) {
You probably don't have the correct encytype="multipart/form-data" property in your <form> tag. Please attach the page and I can maybe spot another issue if adding that doesn't work.
Carlos Quintero
here is the page with the issue
I am attaching the actual page with my issue.
I don't see any issue with this page... It appears that it would work to me. Can you provide FTP access and the url to your test page? I'll debug that one since it is simpler and let you know what I find.
Carlos Quintero
sending a PM thanks in advance
I checked your php.ini file and file uploads are turned off.
phpinfo();
search for the line:
file_uploads Off Off
Carlos Quintero
I've changed the value through the php.ini editor in Cpanel to on, and restarted the server. For some reason, the files won't upload.
They are uploading on your test page now. Maybe you are exceeding size limits also set in the php.ini file. Have you tried uploading the same files from your test page?
