My update is inserting the file path each time the page is updated, regardless if the image is updated
Thread begun 9/12/2020 9:28 am by jo271221 | Last modified 9/15/2020 2:02 pm by Ray Borduin | 1519 views | 5 replies |
jo271221
I compared another page where we are doing the same thing and I can't figure out why one works and one does not.
The event page breaks the path to the image the update horse page seems to be working fine. I have attached both pages and will add FTP info in a PM.
What is the url for the page where I can see the issue?
Please post the sample url you are getting as well as what url you would like to see instead.
jo271221
Pages below. This event is expired so it is ok to update it and test.
I think you can just change this line:
'DefaultFileName' => "".($WADAtbl_posts_update->getColumnVal("image") ) ."",
'DefaultFileName' => "",
Then it won't update the row if a new file isn't specified.
jo271221
Thank you very much! That worked on the update page and I believe it should have worked on my duplicate page but I am getting an error. I copied the Default Name per you and then I also needed to update the redirect on line #118 and the Insert path and line #72
For some reason the image is still getting bumped out on this duplicate page.
On this page you would need to change line 72 to:
$InsertQuery->bindColumn("image", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]?"https://performancehorsehotline.com/files-events-2020/".$WADAtbl_posts_update->getColumnVal("customerid") ."/".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]):$WADAtbl_posts_update->getColumnVal("image",false))  ."", "WA_BLANK");
