sending failed emails back to sender
Thread begun 9/09/2020 7:32 am by Sweens | Last modified 12/08/2020 12:02 pm by Ray Borduin | 2195 views | 7 replies |
Sweens
Hi Ray
I think there used to be a way of sending 'undelivered' message info back to the sender - but it seems all I can do now is create a log file in the database to store such data.
However, the senders don't have access to the database to see the logs, so is there a way I can have 'undelivered messages' sent to the sender?
Chris
That is the return path in the FROM settings. Just click the From... button and you will see it on the bottom. Whatever email address you put there will be for bounced messages.
Sweens
Thanks Ray
I've checked and that is already set - but I don't get any notifications. Might this be something to do with my email host?
Cheers
Chris
You will only get bounce emails if the email domain is correct, but the address is invalid. A lot depends on the receiving smtp server and how it handles bounced emails.
Storing in the database is the only way to capture all outgoing emails. A lot of times there is no way of knowing if an email is actually delivered, so there is no way to identify undelivered emails.
Sweens
Thanks Ray
Sweens
Hi Ray
I've enabled the form to create the error log table - but it hasn't done so and I get the following error:
Deprecated: filter_var(): explicit use of FILTER_FLAG_SCHEME_REQUIRED and FILTER_FLAG_HOST_REQUIRED is deprecated in /home/sites/6b/9/987c0ab293/public_html/webassist/email/phpmailer/src/PHPMailer.php on line 3632
INSERT INTO email_log (`EmailTo`, `EmailFrom`, `EmailSubject`, `EmailBody`, `EmailHeader`, `EmailError`, `EmailStatus`) VALUES (?, ?, ?, ?, ?, ?, ?)
Table 'servername.email_log' doesn't exist
Do you have an sql script of the log table so I could install it manually?
Cheers
Chris
CREATE TABLE email_log (EmailID int(11) NOT NULL auto_increment, EmailTo varchar(250),EmailFrom varchar(250),EmailSubject varchar(250),EmailBody text,EmailHeader text,EmailError text,EmailStatus varchar(50),EmailDate timestamp default CURRENT_TIMESTAMP, PRIMARY KEY (EmailID))
Sweens
Many thanks, Ray
Cheers
Chris
