v1 daterbidge/ compatible with v7php
Thread begun 9/01/2020 12:54 pm by software.current355386 | Last modified 9/11/2020 1:17 pm by Ray Borduin | 5780 views | 33 replies |
I HAVE 21 DAYS TO SORT 15 SITES BUILT WITH OLDER VERSTUN OF PRODUCTS NOT SURUE IF MYSWLI SSB UDSEKDDD
SLL SIET HAVE AN HDACCES FILE POINTING TO V5...6 PHP
HAT DO I NEEND TO DO TO KEEP THEM WORKIMMMGMMMM
SORRY ABOUT THE BAD TYING HAVING A STRESSFUL TIME THIS IS THE LAST THING I WANTED
ANY MIGRATION TOOLLS AVAILABLE
Databridge v2 has migration capability for php7, but 15 sites in 21 days is going to be a lot of work. I'd buy the upgrade to Databridge v2 if you don't already have it and then set up a 1 hour premier support ticket and we can work on migrating one of the sites in the meeting so you can get a head start on what is necessary to meet your time deadline.
RUNNING MSQLI SB ON ALL SITES
CURRENLY RUNNING DB V2 IN DW
WHA TABOUT CNS?
You can download a php7 version of the CMS here: https://www.webassist.com/PowerCMS.zip
PLESE CAN YOU TELL ME WAHAT WILL WORK UNDNENR PHP 7.
PREV VER OEF SB
CMS AS IS OR DI HAVE TO UPGRADE TO THE SQLI VERSION , IS THIS LIVE OR DEMO SOFTWARE
DATBRIGE ORIGINAL OR UPGADE
WILL HAVE TO DO CHANGES ON SIÊ ASE FOR THE WA EXTENSIONSN
WILL TAKING THE HT ACCES A WAY HELP IN ANYWAY
Any MySQL code has to be updated to MySQLi for php7.
The cms in the zip has been updated to mysqli and Databridge v2 has migration capability to update existing code through the server behaviors panel.
THE OLD MYSQLI CODE CREATED BY SB IS COPATIBLE WITH PHP 7
I HAV‰ FORGOTEEN HOOWOO TO INSTALL CMS OR DO I JUST COPY NNEW FILES OVERERITE EXISTING
Any server behaviors that have MySQLi in front are compatible. The old MySQL (without the i) are not and require php6 and below.
You can test if you have mysql code on your page by doing a search for: mysql_
Any code that begins with that is outdated and would have to be migrated.
I just need to replace the site files with the contents of the zip file, run the "getting started with power css tutorial" and then import the exported data file created yesterday, can u think of anything I have missed or got wrong
