Starting over, using Security Assist or MySqli User AUTH..
Thread begun 8/26/2020 10:19 am by Peterson Design Studio - jefferis | Last modified 8/26/2020 11:00 am by Ray Borduin | 1392 views | 3 replies |
Hi Ray, I am finding it easier to rebuild the ability to modify metal prices in a new folder, than trying to trouble shoot and update the old one. This is probably safer anyway. However, I am trying to install security for these pages. I am a bit confused about the options. Is SA now rolled into Databridge2 but the Drop Down Menu still showing SA is part of the new DB2 or is it a legacy option. I was able to install security on all the pages in that folder, but it did not create a login for the security (I used a blank form not a prebuilt because I didn't need a new table, and I think that is why when prebuilt was selected it went into a loop trying to connect to the DB). So, I am using SA to create a login set of pages, but now not sure if/how to apply that session to the other pages where I created managed security.
Also, the MySqli user AUTH is confusing because it created the requirement for username, but did not actually create a login area on the page. Also, since i am using a db with only username and password, I got a few errors (attached)
And I got a couple of errors when trying to create the login pages and selecting an existing page. Errors 3 -5
I am on a MacPro 2013 with plenty of Ram and I notice WA takes a long time between each option when creating any page or feature. Is my system that old or is it a function of the internet speed and db connection, or is it just the secure feature of how WA does code?
You shouldn't be getting these errors. I'm thinking there is a conflict with an older version of the extension installed. If you post your skype name or US phone number I'll call you and do screen sharing to help you get it installed and running properly.
skype name is jefferis
I'll contact you through Skype
