Sending email via smtp - set error message if it doesn't send?
Thread begun 8/26/2020 6:57 am by Mags | Last modified 8/26/2020 9:58 am by Ray Borduin | 2043 views | 4 replies |
Mags
Hi Ray, I've been asked to modify our web contact forms for one client to use their own smtp servers. I've set up a test page using the smtp details they gave me and it's working fine. I redirect to pagename?sent=true on submit and display a success message in the following format:
<?php if(isset($_GET['sent']) && $_GET['sent'] == "true") { ?>
Success message
<?php } ?>
However, I would also like to display an error message if the email isn't sent successfully, for example if the email didn't reach our client's mail server for whatever reason or bounced. Not sure how I would do this though - can you advise if it's possible when presumably the error would be generated by the receiving server?
You can't do it on the web page. It can take several minutes for an email to bounce or even send once received by the SMTP server. The only option is to set a Return Path email address and bounced messages will be sent there.
Mags
Thanks Ray, I thought that would probably be the case.
Mags
Would there be a way of our server knowing if the actual smtp action had failed and displaying an error based on that, rather than it failing at the mailserver?
Once configured properly there wouldn't be an error in the SMTP action itself unless the smtp username or password changed or you pass a mal-formed email address which you could check with form validation. There is an error number and message that would be returned to the email object, but really it shouldn't ever happen once your form is set up properly.
