How do I pass parameters in URL string on Search Results page?
Thread begun 8/25/2020 12:38 pm by lr_leal239405 | Last modified 8/25/2020 2:59 pm by Ray Borduin | 1993 views | 6 replies |
lr_leal239405
How do I pass special parameters to my search results page. I have this search page that I'm passing parameters to successfully on the URL. But, when I press the Search button, I don't know how to pass the same url parameters to the results page.
from
https://www.mywebsite.com/admin/scr/cac_prod_search.php?contact_id=33211&quotenum=98291
to
https://www.mywebsite.com/admin/scr/cac_prod_search_results.php?prod_name=Combo&Search=Search
So, on the above I searched for the word 'Combo'. So how do I add the parameters for example
cac_prod_search_results.php?prod_name=Combo&Search=Search?contact_id=33211&quotenum=98291
I need them for what I'm trying to build. I know may be it can be passed thru session but I would like to see if I can get them thru the URL.
Thanks.
(I can attach the docs if you want to see them)
You can change the action on the search page from:
action="cac_prod_search_results.php"
action="cac_prod_search_results.php?contact_id=<?php echo(isset($_GET["contact_id"])?$_GET["contact_id"]:""); ?>&quotenum=<?php echo(isset($_GET["quotenum"])?$_GET["quotenum"]:""); ?>"
lr_leal239405
huh? I tried that before I contacted you and it didn't work. I'll try again then. Thanks.
lr_leal239405
Ohh. No wonder. I changed the form method to 'Post' instead of 'Get' and it passed those parameters now. Not sure what else will be affected but for now, that's what it was. Thanks.
<form class="Basic_Default" id="Search_Basic_Default" name="Search_Basic_Default" method="post"
lr_leal239405
oh. the results has the if isset get:
$searchWADAcac_prod_subcategory_leveltwo_NEW_WADbSearch1 = new WA_MySQLi_Search("WADAcac_prod_subcategory_leveltwo_NEW","");
if (isset($_GET["Search"]) || isset($_GET["Search_x"])) {
$searchWADAcac_prod_subcategory_leveltwo_NEW_WADbSearch1->clearSearch();
$searchWADAcac_prod_subcategory_leveltwo_NEW_WADbSearch1->setSearch(array("type"=>"Key", "comparison"=>"includes", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("prod_name", "prod_name2", "part_no"), "s", "".(isset($_GET["prod_name"])?$_GET["prod_name"]:"") ."");
So...it has to be GET method. But then it doesn't pass values.
If you want to use get for the form, then you can add them as hidden form elements instead like:
<input type="hidden" name="contact_id" value="<?php echo(isset($_GET["contact_id"])?$_GET["contact_id"]:""); ?>">
That would cause them to be forwarded with the rest of the form.
lr_leal239405
Yup, that last one does it. Thank you.
