Update 2 columns
Thread begun 8/25/2020 5:50 am by Jamie | Last modified 8/27/2020 8:36 am by Ray Borduin | 1124 views | 2 replies |
Jamie
Update 2 columns
Hey Ray
How would I go about, if the below drop down is set to 1 a column 'InStock' is set to 1 on insert?
<select name="ProductDropship" id="ProductDropship" onChange="setTextField();" class="select <?php
if (ValidatedField('contentinsert','contentinsert')) {
if ((strpos((",".ValidatedField("contentinsert","contentinsert").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
?>required<?php //WAFV_Conditional download_insert.php contentinsert(3:)
<option value="" <?php if (!(strcmp("", (ValidatedField("contentinsert","ProductDropship"))))) {echo "selected=\"selected\"";} ?>>Select Type</option>
<option value="0" <?php if (!(strcmp("0", (ValidatedField("contentinsert","ProductDropship"))))) {echo "selected=\"selected\"";} ?>>Stock Item</option>
<option value="1" <?php if (!(strcmp("1", (ValidatedField("contentinsert","ProductDropship"))))) {echo "selected=\"selected\"";} ?>>Dropship Item</option>
</select>
thanks
jamie
What would InStock be set to if that field didn't have a value of 1?
You could set the value of InStock on the insert to: <?php echo($_POST["ProductDropship"] == 1?"1":""); ?>
And set the default to WA_IGNORE if blank.
Jamie
got it thanks Ray
