Converting from MySql - questions
Thread begun 8/24/2020 8:52 am by Peterson Design Studio - jefferis | Last modified 8/24/2020 10:57 pm by Ray Borduin | 3261 views | 15 replies |
Ray, thank you ! for your help last week. I am trying to follow the tutorial on making conversions from mysql to mysqli but when I click on a recordset, I cannot get the WA recordset panel to open as in the tutorial page: http://www.webassist.com/dreamweaver-extensions/data-bridge I can see the recordsets already created in the WA Database panel and I can see the recordsets in the Bindings Panel in DW, but I can't open the WA version f the RS panel. When I go to the WA dropsdown menu it only offers the i version of recordsets but when I click on that, it creates a new one. IOW, I'mhaving trouble converting the old sets to new ones according to the instructions. Also I have clicked in the code where the queries/rs are but it still doesn't bring up the WA recordset panel to change from regular to i.
Also, I am still not sure what Earthliink is doing but it has temporarily reverted the site back to php 5.x from 7. Does MySqli work with php5? Although I can make the connection to the DB, do all the other recordset features work with legacy php?
Forgive me if these are DOH questions, but I have not worked with php for a couple of years. I have been mostly developing WordPress sites or simple html sites that don't require php programming and I am very rusty.
Databridge updated the standard Dreamweaver Recordset as well, so you can use it to update to mySQLi. Just choose the mySQLi connection and Click OK. It should work from both Recordset interfaces.
MySQLi will work on php 5 so you can continue to do your migration.
Hi Ray, I don't think I quite understand... Let me show you where the problem is: https://www.screencast.com/t/UrCtCuIs
I must be doing something wrong or missing something.
You need to go to: Window->Server Behaviors
Then all of the existing recordsets should be listed. You double-click on the one you want to update and then change the connection.
I see where it has even updated my variables on the page. I am surprised! Wow.
<td align="right">$<?php echo number_format (($GoldPrices->getColumnVal('price') * $GoldPrices->getColumnVal('rate') * 0.416), 2) ; ?></td>
But even with everything updated and it seem to show in part on live page view, when uploaded it is drawing a blank page. And I have uploaded the rsobj and the connection script.
Okay thanks. But I may be losing something when I update.
This is the new recordset:
$GoldPrices = new WA_MySQLi_RS("GoldPrices",$LiveGold_i,1);
$GoldPrices->setQuery("SELECT * FROM goldprices WHERE metal = 'Gold'");
$GoldPrices->execute();
This was the OLD recordset. I will lose all the variables it created it think: ?
mysql_select_db($database_LiveGold, $LiveGold);
$query_GoldPrices = "SELECT * FROM goldprices WHERE metal = 'Gold'";
$GoldPrices = mysql_query($query_GoldPrices, $LiveGold) or die(mysql_error());
$row_GoldPrices = mysql_fetch_assoc($GoldPrices);
$totalRows_GoldPrices = mysql_num_rows($GoldPrices);
Is the update not picking up the specific queries? Or has it changed that much?
The output I have on that page currently is using variables created under the old queries:
<td align="right">$<?php echo number_format (($row_GoldPrices['price'] * $row_GoldPrices['rate'] * 0.416), 2) ; ?></td>
That code looks good.
Try adding this to the top of the page and see if you can get an error message with more information:
ini_set("display_errors",1);
Fatal error: Call to undefined function virtual() in /services2/webpages/c/a/cartierbuyer.com/public/goldi.php on line 3
Line 3 is <?php virtual('/Connections/LiveGold_i.php'); ?>
The virtual() function is Apache-specific and it won't work on non-Apache servers.
The solution is to use require_once() instead.
If you update your Dreamweaver site settings, go to Advanced Settings->Local Info and chose "Document" instead of "Site Root" links relative to.
This will make Dreamweaver automatically use require_once() instead of virtual.
The updated code should be:
<?php require_once('../Connections/LiveGold_i.php'); ?>
You will probably have to manually update existing pages or you can probably re-apply the recordset server behavior to get Dreamweaver to update it.
okay, I manually updated but here is the weird thing. Not only does it send a blank page, but it also does not show any errors:
?><?php require_once('../Connections/LiveGold_i.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
$SilverPrices = new WA_MySQLi_RS("SilverPrices",$LiveGold_i,1);
$SilverPrices->setQuery("SELECT * FROM goldprices WHERE metal = 'Silver'");
$SilverPrices->execute();
$PlatinumPrices = new WA_MySQLi_RS("PlatinumPrices",$LiveGold_i,1);
$PlatinumPrices->setQuery("SELECT * FROM goldprices WHERE metal = 'Platinum'");
$PlatinumPrices->execute();
<!doctype html>
<html>
I don't think the error is in that code... Maybe lower on the page.
Can you attach the full page so I can take a look.
Some syntax errors are catastrophic and don't show in error reporting.
