Blank results page
Thread begun 8/24/2020 7:11 am by software.current355386 | Last modified 8/27/2020 2:12 pm by Ray Borduin | 2009 views | 7 replies |
Blank results page
newly generated dataassist page all appear to be ok except for the results page,
which shows an error on the following line
<script src="../webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
the line number is indicating an errror.
looked at the javascript
and there are red line numbers all over
how can i resolve these.
logfile in pm
On line 364 you have:
<td class="WADAResultsNavButtonCell" nowrap="nowrap"><?php if ($WADAdbmScreen->PageNum > 0) { // Show if mysqli not first page ?>
That appears to be a duplicate of line 343. I'm not sure how that line got duplicated, but deleting it seems to have fixed the problems on the results page.
````lost all I typed I iso I will do it as bullet points
generate data assist pages
`results page corrupted
sect box at bottom
half a record nav bar missing s& /form
copied the missing code and screen worked
sear c h box issue when 18 database table to process
I'm a little lost with this post. It looks like you were able to resolve your issue. Maybe try updating the webassist->Preference setting for Wizard Settings and set the delay to "long". That sometimes fixes odd issues like this.
build all the remaining DA pages required
problems with 6 of 16 table
When generating the pages issues when generating update pages
SCREEN SHOTS ATTACHED
Have you reainstalled DataBridge lately? I think these issues have been corrected in the most recent build.
If you still have issues, post your phone number in the private area of a response and I'll call you to do screen sharing and help you get it reinstalled properly.
have reinstalled DB 2 times I've even delete the DW cache file
I have reached out to you in Skype. We can use that to coordinate a time to screen share tomorrow.
