change price
Thread begun 8/20/2020 9:15 am by NWak04030229 | Last modified 8/25/2020 8:56 am by Ray Borduin | 3570 views | 14 replies |
NWak04030229
change price
How can I change the price on an already set up Add To Cart button? I have gone through the forum and have found that in 2013 you changed it through behaviors but when I try to open behaviors on one of my PHP pages it is greyed out.
You just double click on the add to cart button in the server behaviors panel and then you can update the price there.
NWak04030229
Ray - when I am on a page with a Add to Cart button I cannot access Behaviors - it is greyed out. I can't get into Behaviors to do anything. Also, having another problem (sorry about this) - when I do a test I get to the cart.php and fill that in and click continue - I then get to the checkout.php and after filling that in I click continue and get to another checkout page and get stuck. I have attached the screenshot
You should be trying to access Server Behaviors, not Behaviors.
I'd need you to attach a copy of the two files listed in the error to debug why you are having that problem, or give me FTP access to get the files myself. It appears it is code in the wrong order on the page, or potentially a blank line in the code causing issues.
NWak04030229
see pm
Most likely the url changed when you came back from paypal.
Maybe you started at http://www.yourdomain.com and returned to http://yourdomain.com or vice versa.
The best solution to prevent that is to force users to either always or never include the www. in the front of the url. See how here: https://stackoverflow.com/questions/4916222/htaccess-how-to-force-www-in-a-generic-way
NWak04030229
pm
I'm not sure what issues you will have after updating the .htaccess. If you still have issues at that point, please post specific details about the current problem and I'll try to help.
NWak04030229
pm
Some code was in the wrong location on the checkout.php page. There was html code above the <!doctype> tag. I moved it into the body where it is supposed to be and I think that will fix the error.
