Power CMS 2
Thread begun 8/13/2020 3:40 pm by elewis93815 | Last modified 8/17/2020 10:13 am by Ray Borduin | 1513 views | 4 replies |
elewis93815
Power CMS 2
Hi, I'm running into an issue trying to add a "valid" serial number on one of my sites and It's stating that I only have 2 licenses? I've read in the forum that other people are experiencing this same issue. Please advise
PowerCMS should allow unlimited activations if purchased through Design Extender. The original version did only allow 2 activations. If you aren't using it on more than 2 sites then you can reset your activations on your "My Account" page by clicking "All My Purchases" and clicking the "Reset Activations" button.
elewis93815
Power CMS
Hi I’ve attached the screen shot of the pop up I’m getting to this reply. Also I did check and can confirm that I do have Design Extender collection. elewis@ericklewis.net is my WA account associated email.
elewis93815
You could use one of the serial numbers that have activations remaining and that should work. However this is an older version of powerCMS. You might consider using this version instead and then use the DesignExtender serial number instead:
https://www.webassist.com/PowerCMS.zip
elewis93815
Sounds good!, I'll give that a try. Thanks for your assistance.
