Back to post from the detail page to the result page
Thread begun 8/13/2020 8:36 am by Jonas | Last modified 8/13/2020 2:47 pm by Ray Borduin | 1945 views | 5 replies |
Jonas
I have a question.
I have using Data Assist to generate Insert, Update, Result and Detail page.
I understund that then u are on a detail page and press the back-button, you came to the detail page that the post is displayed on (from the repeated region).
But is it surpose to go to the particular post aswell? Like a bookmark.
If not, is it possible to do so in the button link. I have tried used a bookmark, but it doesn't work. And I don't know if this is the right method.
I don't really understand the question. I'm sure what you want is possible. Can you give me a link to what isn't working and I can explain how to make it work?
Jonas
Im sorry, I have no link. But what I want is that the "Back To Result" button on the detail-page that DA generate, goes to the post it came from on the result page. Not only the same page numer. I want it to scroll down to the actual post, and it don't.
The problem now is that then I press the back button it goes to the first post on that page, and not scrolling down to the actual post.
Here's the code DA generate:
<input type="button" value="Back To Results" class="formButton unstyled" id="BackToResults" name="BackToResults" onclick="document.location.href = 'buckets_results.php<?php echo(isset($_GET["pageNum_WADAbucBuckets"])?"?pageNum_WADAbucBuckets=".intval($_GET["pageNum_WADAbucBuckets"]):""); ?>';" />
I see. You would have to add anchor links for each of the records based on the id and then you could add the anchor to the return url links as well.
So on the results page you might update this:
<td class="WADAResultsTableCell"><?php echo($WADAbucBuckets->getColumnVal("buc_id")); ?></td>
<td class="WADAResultsTableCell"><a name="rec-<?php echo($WADAbucBuckets->getColumnVal("buc_id")); ?>"></a><?php echo($WADAbucBuckets->getColumnVal("buc_id")); ?></td>
And then on the details page update:
<input type="button" value="Back To Results" class="formButton unstyled" id="BackToResults" name="BackToResults" onclick="document.location.href = 'buckets_results.php<?php echo(isset($_GET["pageNum_WADAbucBuckets"])?"?pageNum_WADAbucBuckets=".intval($_GET["pageNum_WADAbucBuckets"]):""); ?>#rec-<?php echo($WADAbucBuckets_details->getColumnVal("buc_id")); ?>';" />
Jonas
Nice Ray!
What if I don't want to show the ID column on the result page?
You don't have to. The anchor isn't visible. Just move it to another column and remove the ID column.
