Need help with Cron Job using Webassist code
Thread begun 8/04/2020 7:55 am by lr_leal239405 | Last modified 8/04/2020 10:32 am by Ray Borduin | 1101 views | 2 replies |
lr_leal239405
I have a cron job that works when I load the page, but won't fire up when in Cron. I see that whenever I use the Webassist code, it won't fire, but it will if I get it off. So I tried to rewrite it in pure php, but I still have issues. Can you take a look and let me know if you can help? See files attached
Webassist code is pure php. I can't think of any reason it wouldn't work when run through a cron. My guess is that it something wrong with the cron. What is the cron you used? I could help you debug this in a premier support ticket.
lr_leal239405
So, the Cron is the attached file above. It's to read the incoming emails and put them into a database. When I open the page in browser, it does the work: reads the email and puts it in the database (with Webassist code). When I set the cron job thru Control Panel (Godaddy) to run the file every minute or so, It doesn't put anything into the database. But I know the path to the cron is correct because I tried simplifying it (removing the lines:
<?php require_once('../../Connections/convacc_cx.php'); ?>
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../../webassist/mysqli/queryobj.php'); ?>
it replacing code with per my other file I attached, it runs but I have some blank fields. I guess I need to write the PHP correctly.
I'll try calling you.
