Confirm email form
Thread begun 7/29/2020 8:13 am by Jonas | Last modified 7/30/2020 9:38 am by Ray Borduin | 1008 views | 2 replies |
Jonas
Confirm email form
The contact form I make must have a field that checks the email address. This selection does not appear to be in CSS Form Builder, as far as I can see. Only password can be confirmed. How do I do this?
I prefer to use Bootstrap form design. But at the same time I would like to create the form in WA's Form Builder, so Form Builder writes the code. Bootstraps verification is nice but requires manual coding for advanced verification. While WA's verification is much more advanced (has more choices). Is it possible to combine Bootstrap with WA's verification and use Bootstrap's design.
You can add confirm to the email after the page is completed. Are you looking to add two email address fields and confirm that way? or are you trying to do unique value confirmation in the database? You could also do email confirmation by sending an email with a link back to truly confirm.
I'm not that familiar with the bootstrap validation, so I'd need to see an example and research it to be sure. Client validation that mimics bootstrap would probably require using the bootstrap code. Most likely the webassist server validation could tap into the styles and techniques bootstrap uses directly, you would just have to look at what bootstrap does and mimic it in the written elements.
Jonas
I solved it myself. Now everything is done in Bootstrap.
