PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in queryobj.php on line 651
Thread begun 7/23/2020 3:29 pm by snakeeyes1314512 | Last modified 7/28/2020 9:43 am by Ray Borduin | 1652 views | 3 replies |
snakeeyes1314512
I checked my php error log and see this warning several times. Using PHP 7.3 on VPS
PHP Warning: sizeof(): Parameter must be an array or an object that implements Countable in queryobj.php on line 651.
This was shone once
PHP Warning: Invalid argument supplied for foreach() in file_manipulation/helperphp.php on line 381
Any thoughts?
I'm not sure what would cause the sizeof() error in the rsobj.php file. I've looked through the code and I really can't imagine why that variable would be set wrong... It must have something to do with the context. That code is only used in Multiple Insert or Multiple Update Server Behaviors. If you could reproduce it and sent the page that was causing it, then I might be able to tell... Are there any errors before it that might be related. Sometimes one error leads to another.
The foreach() error looks like it would be caused by a bad argument sent to the file upload function. Again, I'd probably have to see the page that caused it to debug it. Most likely code was out of order and you have since corrected it if it doesn't happen every time you do a file upload from the page that caused it.
snakeeyes1314512
Usually the error log tells me which page triggered the error. In this case it doesn't.
I will try to investigate this further to see which page is trigger the errors.
I will get back as soon as I can identify which page
snakeeyes1314512
I regenerated the code and that fixed the issue. Warnings gone.
Must have been a typo or something in the code on my end.
