Validation fails on remote server
Thread begun 7/22/2020 1:19 pm by john70964 | Last modified 7/23/2020 2:00 pm by Ray Borduin | 1434 views | 4 replies |
john70964
I have some pages which needs to be validated.
On localhost the validation works OK but when I upload the file to the remote server it fails and on NEXT the same page appears but it is completely blank.
I am attaching a file which does this.
Many thanks
John
I'd need FTP access to debug. A blank page implies an error with error messages disabled. If you ad this to the top it might show a better error:
ini_set
("display_errors",1);
john70964
Pls see PM
I placed the code at the top of the page but it did not help.
You have this code at the bottom of your connection file:
if (mysqli_connect_errno()) {
    die('<p>Failed to connect to MySQL: '.mysqli_connect_error().'</p>');
  } else {
    echo '<p></p >';
That is causing the form redirect to fail when validation fails. Just delete that code, or at least remove the else statement to make it:
john70964
Many thanks for the help Ray
