KFM MySQLi Error
Thread begun 7/20/2020 9:19 am by wdtp.com | Last modified 7/20/2020 12:21 pm by Ray Borduin | 1433 views | 4 replies |
wdtp.com
KFM MySQLi Error
I'm in the process of migrating to MySQLi and am receiving the below error when trying to use the KFM Editor. As soon as "Browse Server" is clicked a new window is launched and the below appears.
Warning: require_once(/nfs/c03/h02/mnt/51355/domains/elmo.lizmoore.com/html/webassist/kfm/classes/WA_MySQLi_Query.php): failed to open stream: No such file or directory in /nfs/c03/h02/mnt/51355/domains/elmo.lizmoore.com/html/webassist/kfm/initialise.php on line 19
DataBridge v2 replaces KFM with a better solution: KCFinder
I'd suggest switching to that rather than debugging how to get KFM working.
If you want help updating KFM to MySQLi then I'd need FTP access and a URL to view the error. Did you update any of the KFM files manually? I'd have to see those to understand what is wrong.
wdtp.com
I'm using DataBridge 2.3.5 but I don't see kcfinder anywhere. This particular page was built a while ago. How can I get kcfinder and migrate to that?
Is it as part of your HTML Editor? or stand alone on your page? If you re-apply HTML Editor, then it should update the file manager.
wdtp.com
Thanks!
