mailto content, getting info from database, stripping html tags
Thread begun 7/14/2020 7:28 am by lr_leal239405 | Last modified 7/14/2020 11:07 am by Ray Borduin | 1719 views | 3 replies |
lr_leal239405
Would you know why when I have a mailto: it doesn't remove the the html tags? It's pulling from database with all the tags <p>, <a href=, <br>, etc.
I've tried strip_tags($mycontent) and html_entity_decode($mycontent), but it just keeps pulling all the tags into the email.
I would like this "<p>[first_name],<br /><br />Thank you for your past orders for..." as "Thank you for your past orders for..."
It works only when I copy and paste already decoded text directly from browser but not thru mailto:
Let me know if you can help. Thank you.
Use strip_tags() and pass the "false" parameter to the getColumnValue() reference to ensure the tags aren't already encoded like:
<?php echo strip_tags($WADAemtemplate->getColumnVal("emtemplate_content", false)); ?>
lr_leal239405
Great. Thanks. I think the 'false' parameter did it. It literally strips off the tags so my <a href's become dead links, the list items <li> and all the content becomes one paragraph. How do I then make it so that it interprets the html on the mailto (from the db), rather than strip it off so I would like to keep the formatting for example on the following:
I've never done this, and there is no built in method in php that I know of... but a quick search for "php convert html to plain text" came back with:
https://github.com/mtibben/html2text
That might be something that would work for you.
