I want to populate menu with categories and subs in the root when the store is in a directory named store, Should I include a plugin or new recordset on the page
Thread begun 7/08/2020 4:21 pm by jo271221 | Last modified 8/27/2020 1:59 pm by Ray Borduin | 2467 views | 5 replies |
jo271221
We wanted a landing page that can easily be edited outside of Powerstore, but now would like the content from the side menu of the products pages to display on the home page.
I succesfully created the recordset and binding but am getting a connection error.
I once I get passed that I need to create a repeating region.
I am getting a connection error message:
<br />
<b>Warning</b>: require_once(../store/Connections/PowerStoreConnection.php): failed to open stream: No such file or directory in <b>/home/shopfullhorse/public_html/index2.php</b> on line <b>4</b><br />
<br />
<b>Fatal error</b>: require_once(): Failed opening required '../store/Connections/PowerStoreConnection.php' (include_path='.:/opt/cpanel/ea-php56/root/usr/share/pear') in <b>/home/shopfullhorse/public_html/index2.php</b> on line <b>4</b><br /
I tried ../../store, and /store which neither make sense but I tried anyway and they failed as well. I am not sure what the cpanel error is telling me. Possibly permissions.
Also I don't recall. Am I suppose to delete the Connections/installed.txt file I am thinking that some file was to be deleted after install and another file needed to be modified as it causes errors.
I have attached the page.
Do not delete the installed.txt file. It will try to run the installer again if you do.
I think the path should be: "Connections/PowerStoreConnection.php"
jo271221
I also get an error with this Connections/PowerStoreConnection.php
Fatal error: require_once(): Failed opening required 'Connections/PowerStoreConnection.php'
The correct path is:
require_once('store/Connections/PowerStoreConnection.php');
jo271221
My connection is correct. My recordset shows and bindings and I can insert bindings but the connection shows not found in dreamweaver therefore I am not able to make the repeating region.
We just want to generate a 'site map' so to speak of all the categories and subcategories and display those in the home page.
So are site map is the same content as the side menu found on the products page. Actual site and page in PM along with FTP info again.
https://mystore.com/store/products_results.php?S_ProductName=&S_ProductPrice=&S_ProductPrice2=&Search=Search
You have a mixture of MySQL recordsets and MySQLi code on this page. The repeat region uses MySQLi repeat region, but it is repeating on a MySQL recordset. Those two server behaviors have to be in sync.
