How to, where, using CKEditor, to place code to call AJAX
Thread begun 7/06/2020 3:43 pm by lr_leal239405 | Last modified 7/14/2020 9:36 am by Ray Borduin | 1486 views | 3 replies |
lr_leal239405
I replaced <textarea id='' name='' onChange=''myFunction(this.value)'></textarea> with CKEditor. Where do I put the 'myFunction(this.value)' on CKEditor to run the Javascript / AJAX function?
Thanks.
That code likely has to be completely rewritten. You can find documentation on the onchange event for the ckeditor here:
https://ckeditor.com/docs/ckeditor4/latest/api/CKEDITOR_editor.html#event-change
It will looks something like this at the bottom of the page:
<script>
CKEDITOR.instances.editor1.on('change', function() {
console.log("TEST");
</script>
lr_leal239405
Thanks for this. I got it working. I never knew what you meant by '...code has to be completely rewritten'.
I just meant this.value wouldn't work to get the value, and likely other references in your myFunction would have to be changed depending on what it needs to do. I didn't have full specifics, so I was simply implying that this was only one piece to the puzzle.
I'm glad you got it figured out.
