Referencing MySQLi Recordset Parameters
Thread begun 7/03/2020 11:06 am by wdtp.com | Last modified 7/03/2020 11:49 am by Ray Borduin | 328 views | 1 replies |
wdtp.com
Is there a way to reference the bound parameters in the MySQLi Recordset?
For instance I use two date parameters as a start and end point for a DB query. Can I reference them in the page later so it echoes the default value if the parameter is blank or the passed parameter if present.
It looks like the parameter name is only contained in a PHP comment in the MySQLi code so I wan't sure if it could be done.
You should be able to reference them. I think the first parameter would be something like:
<?php echo($Recordset1->ParamValues[0]); ?>
