Getting Blank Page on Update
Thread begun 6/30/2020 4:13 pm by lr_leal239405 | Last modified 7/01/2020 10:14 am by Ray Borduin | 2061 views | 4 replies |
lr_leal239405
I am getting a blank page when I press 'Update' button on link / page below:
I've tried removing all spaces found but I can't figure it out. It tried the die() to see where and I found on line 97.
$UpdateQuery->redirect($UpdateGoTo);
When I remove the $UpdateGotTo like so: $UpdateQuery->redirect();...
...the blank page goes away but I need the redirect.
Attached is the file.
You also have FTP already on your DW, I believe, to that page (see below)
The page: cac_quote_new_records_update.php is not in the FTP area, so I couldn't test it.
The first thing I'd do is add this to the top:
ini_set("display_errors",1);
That should give you an error message instead of the blank page that you could use to help figure out what is going on.
lr_leal239405
I've checked out the errors and tried several things to clear it up but I haven't been able to solve it.
Sorry. the ftp below should have the page in that folder
You had put an include on the top of the page:
<?php include("jsscripts.php"); ?>
That writes client side javascript to the page before the <!DOCTYPE HTML> tag and before the redirect.
You can't redirect to a new page once the page you are on has started writing code to the page. The solution was to move your include down to the <head> tag inside the <body> which is the top-most location you could put it. (usually you put scripts right before the </body> to help the page load more quickly, but it probably isn't too significant)
lr_leal239405
Oh Wow. Thanks! Awesome lesson. I spent so much time on it yesterday. But....I'm learning a lot.
Much Appreciated!
