International number won't validate
Thread begun 6/25/2020 7:22 am by Justin@AdventDesign | Last modified 7/10/2020 11:16 am by Ray Borduin | 2456 views | 6 replies |
Justin@AdventDesign
I have the checkbox marked for allowing international numbers, but the page still doesn't seem to allow international numbers. When I enter '82-10-3376-3593' it reformats it to '82 (103) 376-3593', but won't allow it. Page attached.
Your date field has:
pattern="\(\d{3}\) \d{3}[\-]\d{4}"
but it looks like the pattern should be:
pattern="\d2 \(\d{3}\) \d{3}[\-]\d{4}"
Justin@AdventDesign
That makes sense, but it appears whether I do or do not check for allowing international numbers the pattern won't change. I'll try it manually.
Yes. That is the client validation. You would have to change that manually. The server validation is separate. You could remove the pattern attribute entirely and just use the server validation.
Justin@AdventDesign
Thanks Ray. That second to last set of numbers needs to be 3 or 4 digits, depending upon the country. As is it still wants to alter 82-10-3376-3593 to 82 (103) 376-3593. I can't seem to find a guide for how the pattern coding works. I tried changing \d2 \(\d{3}\) \d{3}[\-]\d{4} to \d2 \(\d{3}\) \d{4}[\-]\d{4}, but that doesn't do it. Where can I find more information on coding the pattern?
Remove the onblur code from the fields... That is what is doing the reformatting.
For a true international phone validation, try using:
^\+(?:[0-9] ?){6,14}[0-9]$
I found it here:
https://www.oreilly.com/library/view/regular-expressions-cookbook/9781449327453/ch04s03.html
For more examples google "International phone number regular expression"
Justin@AdventDesign
Thanks Ray. I actually came across some things like that but they looked so drastically different from what we had I thought it must be a different coding system or something. I'll give it a try.
I actually like the reformatting as it makes it consistent but I'm guessing that it may not be possible with such a variety of numbers dealing with international numbers.
