I don't need address 2 but I need 'Male - Female - Other' dropdown
Thread begun 6/21/2020 6:46 pm by Gizza372666 | Last modified 6/23/2020 8:45 am by Ray Borduin | 634 views | 1 replies |
Gizza372666
1. Can you please replace the following code with a dropdown menu with the option 'Please Select, Male, Female, Other':
users_registration.php
<p>
<label for="UserAddress2">Gender:</label>
<input type="text" class="WAATKTextField" name="UserAddress2" id="UserAddress2" value="<?php echo( htmlspecialchars( ValidatedField("usersRegistrationfull","UserAddress2")) ) ?>" size="32" />
</p>
2. Can you please replace the following code with a dropdown menu with the option 'Please Select, Male, Female, Other':
users_update.php
<p>
<input type="text" class="WAATKTextField" name="UserAddress2" id="UserAddress2" value="<?php echo( htmlspecialchars( isset($_GET['valid'])?ValidatedField("usersUpdate","UserAddress2"):$WADAusers->getColumnVal('UserAddress2') ) ); ?>" size="32" />
</p>
3. Can you please replace the following code with a dropdown menu with the option 'Please Select, Male, Female, Other':
users_profile.php
<p>
<input type="text" class="WAATKTextField" name="UserAddress2" id="UserAddress2" value="<?php echo( htmlspecialchars( isset($_GET['valid'])?ValidatedField("usersProfile","UserAddress2"):$WAATKusers->getColumnVal('UserAddress2') ) ); ?>" size="32" />
</p>
looking forward to your reply.
Thank you in advance.
I know if I try to change the var name I will have to make a lot more modifications so just leave the var as 'UserAddress2' that's ok with me.
next time you update the 'Power Messenger' can you please also add gender?
Ps.
Email Token doesn't work.
When I select the option, I can select, first name but when I click to confirm, it doesn't add the token into the html email template. (can you please give me the structure of the token to add (Dear First Name Last Name). Thanks again in advance.
1. users_registration.php
<p>
    <select class="WAATKSelectField" name="UserAddress2" id="UserAddress2">
      <option value="" <?php echo((ValidatedField("usersRegistrationfull","UserAddress2") == "")?"selected":""); ?>>Please Select</option>
      <option value="Male" <?php echo((ValidatedField("usersRegistrationfull","UserAddress2") == "Male")?"selected":""); ?>>Male</option>
      <option value="Female" <?php echo((ValidatedField("usersRegistrationfull","UserAddress2") == "Female")?"selected":""); ?>>Female</option>
      <option value="Other" <?php echo((ValidatedField("usersRegistrationfull","UserAddress2") == "Other")?"selected":""); ?>>Other</option>
    </select>
</p>
2. users_update.php
<p>
      <option value="" <?php echo((isset($_GET['valid'])?ValidatedField("usersUpdate","UserAddress2"):$WADAusers->getColumnVal('UserAddress2') == "")?"selected":""); ?>>Please Select</option>
      <option value="Male" <?php echo((isset($_GET['valid'])?ValidatedField("usersUpdate","UserAddress2"):$WADAusers->getColumnVal('UserAddress2') == "Male")?"selected":""); ?>>Male</option>
      <option value="Female" <?php echo((isset($_GET['valid'])?ValidatedField("usersUpdate","UserAddress2"):$WADAusers->getColumnVal('UserAddress2') == "Female")?"selected":""); ?>>Female</option>
      <option value="Other" <?php echo((isset($_GET['valid'])?ValidatedField("usersUpdate","UserAddress2"):$WADAusers->getColumnVal('UserAddress2') == "Other")?"selected":""); ?>>Other</option>
    </select>
</p>
3. users_profile.php
<p>
      <option value="" <?php echo((isset($_GET['valid'])?ValidatedField("usersProfile","UserAddress2"):$WAATKusers->getColumnVal('UserAddress2') == "")?"selected":""); ?>>Please Select</option>
      <option value="Male" <?php echo((isset($_GET['valid'])?ValidatedField("usersProfile","UserAddress2"):$WAATKusers->getColumnVal('UserAddress2') == "Male")?"selected":""); ?>>Male</option>
      <option value="Female" <?php echo((isset($_GET['valid'])?ValidatedField("usersProfile","UserAddress2"):$WAATKusers->getColumnVal('UserAddress2') == "Female")?"selected":""); ?>>Female</option>
      <option value="Other" <?php echo((isset($_GET['valid'])?ValidatedField("usersProfile","UserAddress2"):$WAATKusers->getColumnVal('UserAddress2') == "Other")?"selected":""); ?>>Other</option>
    </select>
</p>
I was able to reproduce the issue with tokens not working. I've updated the code to fix it. Please update the attached file:
/webassist/ckeditor/plugins/EmailTokens/dialogs/EmailTokens.js
Once you update that file the add token button will work in the editor and you can copy/paste it to add it to the subject.
