Delete record using multiple values (filters)
Thread begun 6/18/2020 10:39 am by Steve | Last modified 6/19/2020 5:36 pm by Ray Borduin | 940 views | 2 replies |
Steve
Not a question but rather a solution in case anyone needs a tighter delete query:
$DeleteQuery->addFilter("psaType", "=", "i", "".$companyType ."",  "AND ", "psaProject", "=", "".$projectTarget ."");
If you add a second variable to filter, just add the AND and parameters as shown above.
Maybe in the future the Filter will be like the Bindings view where multiple values can be set for more complicated Delete routines.
I just noticed I did not add a second "i" for integer. Optional?
This should actually be done with multiple filter calls like:
$DeleteQuery->addFilter("psaType", "=", "i", "".$companyType ."");
$DeleteQuery->addFilter("psaProject", "=", "i", "".$projectTarget ."");
You can add multiple filters manually, it just isn't supported from the interface. They are always joined with AND and you can add as many as you want.
I don't think your example would work. I believe the second filter is ignored.
Steve
Thanks Ray,
I see the behavior rewrote my manually created filter by creating a new second filter
$DeleteQuery->Action = "delete";
$DeleteQuery->Table = "projects_companies_assigned";
$DeleteQuery->execute();
That explains why it was working. I did not see the additional line originally.
