I got a script issue that keeps tying up my Dreamweaver WA_UI.js
Thread begun 6/15/2020 7:31 am by lr_leal239405 | Last modified 6/16/2020 2:38 pm by Ray Borduin | 3447 views | 10 replies |
lr_leal239405
My Dreamweaver keeps hanging up on:
"A script in file c:\Users\name\AppData]Roaming\Adobe\Dreamweaver2020\en_US\Configuration\Shared\WebAssist\Library\WA_UI.js has been running for a long time. Do you want to continue?"
Any insight? I'm going to try to clear cache.
levin
lr_leal239405
The clearing of cache didn't work. Also I tried going back to DW 6. I get the same Also, after I press OK it it says:
Error translating content:
Error: The user chose to stop the script.
lr_leal239405
I have the editor 3x in the page. Looks like when I take one out, it starts working. I copies and pasted it originally and just change the id name. I'm inserting it instead now from the Webassist dropdown tools. Let me see if that makes a difference and script won't run endlessly any more.
Please attach the page causing the issue and I can reproduce it and debug it that way to try to find a solution.
lr_leal239405
Try this
Try updating:
$CKEditor_initialValue = $quote_note;
$CKEditor_initialValue = "".$quote_note ."";
It looks like you hand coded that section and it is getting confused since it expects the value to begin and end with a double quote.
lr_leal239405
ok. I don't get the 1.5 minute hang up any longer. it works but I do get a popup when trying to upload that says
"It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies."
I press 'ok' and it goes away.
lr_leal239405
maybe because I renamed my wincache file to backup. Then I rebooted recently. Now the system got rid of it. I guess I have to rerun webassist tools reinstall. I'll try that.
lr_leal239405
Sorry to bother you. Maybe related to my previous post.... I'm constantly getting popups below (one after the other) on Dreamweaver in general. I can keep pressing ok for now , but maybe you know why.
The WA eCart AusPost script does not define the findServerBehaviors function.
The WA eCart DHL script does not define the findServerBehaviors function.
The WA eCart FedEx script does not define the findServerBehaviors function.
The WA eCart UPS script does not define the findServerBehaviors function.
The WA eCart USPS script does not define the findServerBehaviors function.
The WA eCart Upload Files_WA script does not define the findServerBehaviors function.
The WAFV_ShowIf script does not define the findServerBehaviors function.
I did try running reinstall for eCart and DataBridge but it did not fix it.
Try deleting the winfilecache.dat file with Dreamweaver closed. If that doesn't work, then try reinstalling eCart. If that still doesn't work then I may have to do screen sharing to debug it with you... unless it happens on a particular page and you could send me that page for me to debug it directly.
