How to set multiple datas?
Thread begun 6/12/2020 3:24 pm by Steve | Last modified 6/15/2020 10:12 am by Ray Borduin | 1141 views | 3 replies |
Steve
Hello,
I have two cases where I am asking WebAssist best practices before I head off to create arrays and write my own code.
1) I have a page with a number of checkboxes in a checkbox group that once selected will be used to email to all selected recipients
<input type="checkbox" class="form-check-input"  name="CheckboxGroupGCs[]" value="<?php echo($Contacts->getColumnVal("pcEmail")); ?>" id="CheckboxGroupVendors_<?php echo($Contacts->getColumnVal("pcID")); ?>">
It looks like the Send Mail behavior is set up to use results by imploding an array of results/values on $_POST:
$Email->addTo("".((isset($_POST["CheckboxGroupGCs"]))?implode(",",$_POST["CheckboxGroupGCs"]):"")  ."");
2) What about Inserting a record of all the selected values? I would like to assign two value on Insert ($target and $emailID). Each would insert as a unique row.
Is there something already built into the MySQLi Insert Behavior or should I loop the Insert Behavior, or collect all the records into an array then Insert while looping through the array?
Thanks in advance for the guidance,
Steve
I see there is an Insert Multiple Records behavior so that effectively solves inserting many records.
Actually the regular insert would work as well. Just bind the value as an array and it will automatically convert it to insert multiple records.
Steve
Thanks Ray, yes the standard insert worked fine accepting an array which required making the checkbox name with the square braces[].
The Dynamic checkbox select if equal to did not work as well as it kept inserting independent values with each test:
<input
<?php if (!(strcmp(($Companies->getColumnVal("companyID")),$Companies_assigned->getColumnVal('psaCompany')))) {echo "checked=\"checked\"";} ?>
<?php if (!(strcmp(($Companies_assigned->getColumnVal("psaCompany")),"Y"))) {echo "checked=\"checked\"";} ?>
<?php if (!(strcmp(($Companies_assigned->getColumnVal("psaProject")),"$Companies->getColumnVal(\'companyID\')"))) {echo "checked=\"checked\"";} ?>
type="checkbox"
name="CheckboxGroup1_<?php echo($wa_startindex); ?>"
value="<?php echo($Companies->getColumnVal("companyID")); ?>"
id="CheckboxGroup1_<?php echo($Companies->getColumnVal('companyID')); ?>_<?php echo($wa_startindex); ?>">
This was easiliy surmounted by putting the recordset in an array and using the PHP in_array function:
<input <?php if (in_array($Companies->getColumnVal("companyID"),$nameArray)) {
type="checkbox"
name="CheckboxGroup1[]"
id="CheckboxGroup1_<?php echo($Companies->getColumnVal('companyID')); ?>">
